Krell KSA-250
Just started moving around today.... Had an emergency root canal at 3 yesterday.................... Broke a tooth, and broke a filling in the one next to it. Molars with 3 roots SUCK. Luckily the "Butcher of Bagdad" hooked me up for $700 for an hours work............. Fucker.............. And we aint even counted the 2 crowns.
Root canals are SOOOO(OOOOOO much fun....done with that now, not a tooth left in my head...
That sucks, you need some real white lightning to keep the wound clean, ----- and for pain of course
Perry you keeping this brute when done my friend in Florida had to run a extension made up of some fuckin welding cable from the breaker box.
Following with great interest Perry. Got that KSA 150 that needs done here too.
I wonder if the 250 and the 150 share the same "Slow Start" board??? I'll have to dig into that. Maybe I'll try to make a new board. It's a pain with a shitty skizmo especially if there were a couple different versions and only ONE skizmo. I could simplify it and beef it up and eliminate some of the voltage switches and use a beefier relay.
Couple months ago i saw i guy in Taiwan was selling slow start boards for the Krells thick boards and large traces have to go back and look
Sniffer, as far as those S.S. boards go I have seen more than one .rev. on line in my peepin around. Mine was a little different lay out wise than others in the KSA series. I did not take pictures but it does have those hot as hell not standing off far enough big ass green resistors that need a heat fukin heat sink. Two of them of cores. Saw a cat come up with a way of using two wire wound heavy duty resistors mounted to the front plate off that board with wire.
We have been moving the resistors to the other side of the board when replacing them. Stand off is also done.
