Junk compared to the 95's and 96's
Originals appear to be private branded MJ15024/25s
Perry is correct, the 95/96s are better devices.
Perry, You been lifting weights to get ready to lift that on the bench?
You spoke to the Chief Operating Officer at Krell? You must have a lot of pull with those guys, too bad they blew you off. Probably should have spoken to the junior technician, he likely would have helped you.So I sent Krell a request for the schematics for this KSA-250. The COO kindly pointed out that there was a sticker on the amp that said "No User Servicable Parts Inside" an I should take my amp to an AUTHORIZED" service shop and they would "Sort" my amp out. Fuck Krell. What a bunch of pompus twats.
Good read Fred...
Good Lord.
Dan D'Agostino Relentless Monoblock Amplifier
$295,000.00
They had a niche market segment; excellent specifications, high quality components, attention to detail, ridiculously/astronomically high prices. Joe, you have nothing to worry about - you only match three out of four of their market segment qualities.Good Lord.
$295,000.00
Started replacing components and reworking the "Slow Start" board. I replaced the caps which were overheated from the 700 Ohm resistors which I moved to the opposite side of the board, replaced the precision resistors, bridge rectifier, and got most of the diodes replaced too. Still waiting on the other $400 worth of parts to get here. The price of the 4 Bulk caps, and the 4 relays brought the price up there. Damn relays were $17 each and the bulk caps were $60 each. The emitter resistors added up too when I needed 50 or so.... Since I have the schematic for the Slow Start board, I wonder if it would be worth it to have some made. I know there are a couple parts I have not been able to find. Like the Zettler relay's (AZ845-12). I had some new Opto-Couplers from a Carver Amp job so since I had them, I replaced them. There are 2 on the SS board, and a few others on each output board. Onward an upward.... HUH?
View attachment 47988View attachment 47989
