If I knew I could get away with it, I'd eliminate the "Slow Start" as designed. Maybe I'll post the Schematic and see if anybody thinks it's feasible.
https://neurochrome.com/products/intelligent-soft-startIf I knew I could get away with it, I'd eliminate the "Slow Start" as designed. Maybe I'll post the Schematic and see if anybody thinks it's feasible.
I don't want to give away any of my secrets to KrellRev D which is what I have. Got the AC in on the left side, and the circuitry to the 60LB Toroid Transformer on the Right and the L/R+ and L/R- Sense on the bottom left. The Remote isn't even there. I have the skizmo finished in CAD but would like to come up with something a little less "CRAZY". Any IDEAS???? The 700 Ohm resistors (R1/R2) get so hot they char the board and will destroy it without intervention. It was too late for mine.
I don't want to give away any of my secrets to Krell![]()
I see the problem Perry, they need more relaysThey won't even fix their OWN shit Joe.......![]()
I see the problem Perry, they need more relaysSoft starts are complicated but not that complicated. They have a standby circuit it seems which is always alive.
Why are the 700 ohm resistors getting so hot Perry? Are they small board mounted resistors?
You mean the 7.5 ohm resistors?
That is just silly design Perry. The value of that series resistor ends up being 1.8 ohms which is a ridiculous value for a soft start resistor.
