Krell KSA-250
#81
Just started moving around today.... Had an emergency root canal at 3 yesterday.................... Broke a tooth, and broke a filling in the one next to it. Molars with 3 roots SUCK. Luckily the "Butcher of Bagdad" hooked me up for $700 for an hours work............. Fucker.............. And we aint even counted the 2 crowns.
#83
Root canals are SOOOO(OOOOOO much fun....done with that now, not a tooth left in my head...
stetter
Tower, MN
#84
That sucks, you need some real white lightning to keep the wound clean, ----- and for pain of course
krellmk
Brooklyn NY
#90
Perry you keeping this brute when done my friend in Florida had to run a extension made up of some fuckin welding cable from the breaker box.
#94
Following with great interest Perry. Got that KSA 150 that needs done here too.
I wonder if the 250 and the 150 share the same "Slow Start" board??? I'll have to dig into that. Maybe I'll try to make a new board. It's a pain with a shitty skizmo especially if there were a couple different versions and only ONE skizmo. I could simplify it and beef it up and eliminate some of the voltage switches and use a beefier relay.
VSAT88
Phenix City Alabama
Like my BlueTooth ?
#98
Sniffer, as far as those S.S. boards go I have seen more than one .rev. on line in my peepin around. Mine was a little different lay out wise than others in the KSA series. I did not take pictures but it does have those hot as hell not standing off far enough big ass green resistors that need a heat fukin heat sink. Two of them of cores. Saw a cat come up with a way of using two wire wound heavy duty resistors mounted to the front plate off that board with wire.
#99
We have been moving the resistors to the other side of the board when replacing them. Stand off is also done.
