phase linear 700 vs 400
FredR
DFW
WTF?
#61
The faceplate is easily scratched. Use any tools on the back rather than front.
FredR
DFW
WTF?
#62
Sorry if I'm sounding too fatherly. One of my kids is your age.
K-5BLAZER
las cruces nm
square body cause I dint want a plastic 4x4
#63
K-5, the amp should be there tomorrow or the next day. Before powering it up, if you comfortable doing it, take off the faceplate and make sure the four (two on either side of each meter) hold down screw clamps are still in place. If the come loose they can cause major problems. I don't glue them down cause I'm always moving stuff around. Also, I don't use a metal retaining bracket on the bulk capacitors on the left side of the photo because it interferes with the bridge rectifier wiring. Also looks much better :D. Instead I hot glue the capacitors down. Make sure they are still solidly held.
Finally and most importantly, there are hideously dangerous voltages in the amp. Button it up before you power it up. Also, be kind to your ears. I expect they are even more important to you than most of us!
Noise induced hearing loss:
http://dangerousdecibels.org/education/information-center/noise-induced-hearing-loss/
well next week I am going to see a good friend of mine I will have him open it and insect it is it ok if need be to spay it out with compressed air
K-5BLAZER
las cruces nm
#64
not a problem at all
I am looking forward to playing first at my friends and then at my home the only thing that I think could be bad is since I live in single wide trailer my room is quite small
FredR
DFW
WTF?
#65
No dust. Guaranteed. Looks just like Dorothy. Be sure to forward my instructions and warnings.
Fishoz
Northeast Illinois
Always learning!
#68
You're not going to have a problem. Read up on near field listening. Find you're sweet spot and you will be in heaven. Might take some trial and error on placement, toe in you're speaks a bit if necessary.
#69
Couldn't hear you....
Me either!!!
On a side note, just dug 3 vehicles out (our Pathfinder, the rental and Makala's Ford F150, shoveled 100lb per shovel full snow full of water, snowblower died so Jake and I went at it
I feel like an old motherfucker right now, stupid winded, feels like my heart is going to blow through my chest
This is the weirdest storm I have seen in years, foot of snow and then it rained on it for a couple hours, still raining on the shit
#70
K-5, DO NOT LET SOMEONE WHO KNOWS NOTHING ABOUT THESE AMPS TOUCH FRED'S AMP
Unloosen the nuts ON THE BACKSIDE OF THE PLATE
Carefully lower the plate forward so you do not pull the light board wires out
You will see if the meters are loose, if so, get on the board or call one of us. If they are not, bolt the faceplate back up and tighten from the back using a box wrench to hold the bolt on the front
#71
Me either!!!
We have Three stooges weather...No Moe Snow!
And to answer you be CAREFUL, you and all of us are old Mofos. You could be the poster child, but please don't die before you run the risk of going blind? :blob4:
#72
I jest, but two of the biggest killers of men are heart attacks shoveling snow....
and FLY FISHING
(I.E. falling out of the boat with an open fly) :toothy5:
#73
Me either!!!
Still snow up here in the great white north...
#74
Looks like Maine is getting crushed. I have not heard from our member up in Maine roccus???
#78
It's all good bro, I am half blind also (cataracts and Fuchs Corneal Dystrophy) and the only reason I don't have many typo's is that I learned to type in high school without looking at the keyboard LOL
We should spay all our insects anyway, especially mosquitos :iconbiggrin:
FredR
DFW
WTF?
#80
K-5
Charlotte shows delivered and signed for by Lisa Brake.
A little background on Charlotte. I bought her off eBay in early 2014 for parts or not working. The seller said he tried to power her up but she started sparking and smoking and then blew a fuse. When she arrived I found auto fuses in the AGX fuse holders. You’d be surprised how often stupid stuff like that happens. She also was covered in cigarette tar outside and smelled terrible. Opened her up and the inside was a mess. Dirty, burned, and also smelling of cigarette smoke. Otherwise she was in pretty good cosmetic condition, other than a scratch at the top of the faceplate. OK, some work to do. We start a WOPL conversion of an amp in this bad a condition with a “bare metal†rebuild. See photo of Charlotte after I gutted her.
