 - Mar 6, 2022
thanks george!!!!Page 4, and you have Bose, so you may have additional issues.
i appreciate the manual....
Does anyone here know how to remove this? Joe if you are around can you please explain.Could be a safe operating area (SOA) issue. Exact issue I encountered. On all my WOPLs I've disabled that protection so I can drive 2 ohm speakers. No problem since. Most don't recommend that balls to the wall approach. Fuse protection is still there. Ask Joe about it.
Fan required.
i am already a member...to both...thank you....Gene,
https://www.hifiengine.com/
Excellent site with most manuals. Become a member!
And Don Watts Abundant Audio Karma hosted manuals, very good scans!
http://akdatabase.com/AKview/thumbnails.php?album=94
Thanks I will separate the wires.Myself, not a clue on how to remove it. Joe should have some suggestions on resolving your issue without removing it, I would think.
My 4 ohm stereo subs are single driver Dayton Audio 15" Ultimax in the recommended precut flatpack cabinets from Parts express with no internal crossover. A active MiniDsp 2x4 crossover feeds two WOPLS. One for the stereo subs, one for big stereo JBL Millenniums. Never a issue like you've described.
I did see one issue in your wiring if I remember correctly. Think you had the flying yellow output wires from the backplanes to the DCP zip tied to adjacent wiring.
This is error, think about it. All that AC signal output is in those wires is being inducted into adjacent wiring. Those need to be kept as far away from other components as possible and fly between the points. Sending this then I'll look for a 400 photo.
Yellow wires on a 700, you get the idea.
I also been running my Amp into Lower ohm speakers (impedance I have not tested yet) and they sounded great until I turn them up loud (w more bass it happens at lower Volume) than I get a ripping sound thought the Tweeter , is that what you had? before disconnected the protection circuit?Could be a safe operating area (SOA) issue. Exact issue I encountered. On all my WOPLs I've disabled that protection so I can drive 2 ohm speakers. No problem since. Most don't recommend that balls to the wall approach. Fuse protection is still there. Ask Joe about it.
Fan required.
Joe found that Gene had the Mica capacitors that were pushed to far into the Control Boards , The Mica capacitors from the factory had crud on them which leak down the leads and could also leak when heated up which could cause a bad solder joint. Gene found one open (I also install mine pushed into the board to far I was suppose to stand them up w a Gap) Gene do you remember which one it was? this will cause noise problem and spikes sounds (they are used for preventing High Fhz noise ,,,,,, and more related to this) I see your are also install pushed in?4.1 ohms View attachment 68284
No changeThanks I will separate the wires.
no...i really dont remember ... i tested all through the traces and found some things i did not like ..i cleaned the legs and resoldered...it worked...Joe found that Gene had the Mica capacitors that were pushed to far into the Control Boards , The Mica capacitors from the factory had crud on them which leak down the leads and could also leak when heated up which could cause a bad solder joint. Gene found one open (I also install mine pushed into the board to far I was suppose to stand them up w a Gap) Gene do you remember which one it was? this will cause noise problem and spikes sounds (they are used for preventing High Fhz noise ,,,,,, and more related to this) I see your are also install pushed in?
I took all mine out w a Desoldering station and cleaned them up and re-installed them.no...i really dont remember ... i tested all through the traces and found some things i did not like ..i cleaned the legs and resoldered...it worked...
The EQ has been serviced and is running better than new. I also ran the system without EQ same thing. Thanks for all your help.May have missed it, but have you tried it with the equalizer out of the system completely?
Those equalizers are well past due for a recap.
After seeing the photo, I understand why you want to use the Bose.
