mr_rye89
Bose 901s soak up a lot of power due to the steep eq curve. Consider another 400 or a 700
			Trying out another preamp will let you know.did you try a different preamp? Your pre may be doing it.
Speakers sound good running 8 ohmNext, try another set of speakers
both through tape monitor and connecting between pre amp and amp same result.How do you have the EQ hooked up (for the 901's)?
2 speakers running 8 ohm no problem. 4 speakers running 4 ohm clipping as soon as volume get loud.I thought you said it was distorting right away
