WOPL running 4 Ohm speakers
#43
Why would you THINK you need to add another set of 901's in parallel???? Was the single set not loud enough??? Holy cow...... You can run 2 amps off your pre and run the other set off the second amp
plex
#52
Maybe you think you ran them in parallel 50 years ago, maybe you wired them like the book says 50 years ago.
Dude anything not to believe me? I just changed the speaker wire not too long ago-I could take a picture of that too. Same old oxidated speaker wire we had from the 80s, soldered in parallel-we replaced it.
#53
Well, don't know what to tell ya. The book says no way.................... and, it works with one set like the book says.
#54
Just so you know, attach your ohm meter to the parallel speakers. Its probably in the 3 ohm range and that can go lower at certain freq's.
Gibsonian
#59
So evidence suggest something awry in the WOPL process. I'd send that amp to someone here who is well versed in the WOPL.
#60
I understand about the cooling 4 fin vs 8 fin. But clipping is happening right away.
i too used an old 4 fin junker...i build an extra set of fins to boost cooling ....
i replaced the original rectifier to a bigger one that joe recommended....
i used white oaks power supply cap upgrade....
my transformer/rectifier setup gives be a full +-82v....more than enough to drive to full power...
i did use the white oak chassis because my junker did not have top and bottom plates and i wanted the improved power socket and extras included with the heavier chassis....
sniff recommends these aircom cooling fans for heavy use...
https://www.ebay.com/itm/3325218315...aeJ5BixoJKUEDXeononl/KBPpTkk|tkp:BFBM2ITV5dpg
i have not done so yet....as i will build a new enclosure for my systems...and incorporate a cooling system when the time comes...
but, i dont push mine over 110 db....a little better than half way using schiit modi3 dacs with schiit magni 3+ and heresy preamps...
thats plenty loud enough for me...
