Joe found that Gene had the Mica capacitors that were pushed to far into the Control Boards , The Mica capacitors from the factory had crud on them which leak down the leads and could also leak when heated up which could cause a bad solder joint. Gene found one open (I also install mine pushed into the board to far I was suppose to stand them up w a Gap) Gene do you remember which one it was? this will cause noise problem and spikes sounds (they are used for preventing High Fhz noise ,,,,,, and more related to this) I see your are also install pushed in?
