- Jan 14, 2011
- Gillette, Wyo.
Why are pin three's of the Backplane Boards not connected to Pin three's of the Control Board?
1st gen backplane board...
It came from here Mark. The PL400 backplane needed this change to support full comp operation properly. This is a 700 but was wired this way.Why are pin three's of the Backplane Boards not connected to Pin three's of the Control Board?
You have removed D80 as a potential culprit. Since it regulates properly some of the time and flakey the other times the focus now turns to:D80 Zener Lifted
Same Results:
VR1:
C 20.2 Volts, Sometimes 7.6, Sometimes 7.6 Then 20.2 for a short time after power down.
A 0 Volts
R 2.5 Volts
VR2:
C 0 Volts
A -20.5 Volts
R -17.0 Volts
I Will now clean the side of the board with the components on it.
Is R85 intact (not cracked, burned, etc.)?
Does R85 have a solid 100V on one side when you are getting the 7.6V output or is it also dropping?
Does the collector of Q1, the MJE15032 have a solid 100V on it?
If all those things check out, the focus narrows to a flakey VR1.
blown pico fuse?0.75 Volts on top end of R85, and for some strange reason 0 volts on the C Pin of VR1
blown pico fuse?
Got it. (Thanks Lee) I could not see the Backplane Rev version in the picture.It came from here Mark. The PL400 backplane needed this change to support full comp operation properly. This is a 700 but was wired this way.
The pico fuses are on the backplane. With your probing around could you have accidentally blown he positive rail pico fuse?
you are probing in a sensitive area
