Australia
Measure it with the power off...is Q1 any good? BCE measurements?
I finally found where my email notifications were going, should be able to reply faster now
R85 Measures 24 ohms, Rises to 25 Ohms after a minute or so. R85 Measures 0 volts with power off.
As for Q1, do you want me to measure it in volts or ohms and with power on or off?
R85 should measure 20K, not 24 ohms.
Measure Q1 with the diode scale on your DMM
Australia
I had the meter set to 200k range when I got 24 on the R85, not sure if this makes a difference.
Left hand pin of Q1 makes the multimeter beep and I get a value of 9
Middle Pin just says 1 (like its out of range of meter)
RIght hand side pin Says 1 also
Q1 is an NPN transistor. You are going to diode checvk each junction in that transistor, power off, Positive lead on pin 1 ( if the front is facing you with the pins down , far left is base) negative lead on pin 2, then pin 3. Should have around .600 volts DC on diode check...
Australia
This is with power off?
