BlazeES
- Aug 17, 2011
Avoid the noid.
Go into Device Manager and run the update drivers function,
allowing Windows to search online. The repository of drivers
at Microsoft's disposal is huge now and it will do a good job
assigning the right drivers on older machines with much success.
Yeah I tried that without luck on the drivers that I needed. Win 10 blocked the devices from working and told me I needed to contact the vendor. Asus had a driver utility for win 10 that will update install compatible drivers, worked with everything except for the network card. When it updated the network card I couldn't connect, so I uninstall the Asus driver and went to the windows driver update and the windows one worked.
The Windows driver update told me it couldn't find a better driver, but in the device properties it gave a code 48 saying that this driver has known win 10 issues and to contact the vendor for the device driver.
I still have one driver to work out, but it is for usb card reader, not a big deal at this point.
The number two lesson is make sure you have working drivers installed be fore rebooting the first time.
It is all in a day's work.
The board is an Asus Sabertoooth 990FX.
Asus has a utility called "Drivers for Life" which looks like it was hastily put together with spelling errors and syntax errors. It scans your installed board drivers and recommends backing up certain ones. I think they use Backup instead of Update?Anyway by selecting backup it looks to be installing new drivers.
The Drivers for life found issues with a handful of usb drivers, usb 3.0 drivers, lan drivers, and video drivers. It was tough navigating without a mouse since none of the usb ports worked at all. The board has one PS2 Port but of course I tossed all PS2 mouse or sent them to Orange. I finally found a PS2 to usb converter in my parts bin and was able to at least get a working mouse.
The drivers it want to install for the Realtek network card don't work in Win 10, but the drivers Windows installs do work.
I still need to go through and make sure the other devices such as sound work too, just didn't have time last night.
That's a nice mobo.
About that utility,
you mean 'DriveTheLife '... right?
I don't think my version had the update button though, it was labeled Backup or something stupid like that.
Yeah that's probably it. Not in front of the computer right now.I don't think my version had the update button though, it was labeled Backup or something stupid like that.
Although you can use it to back up your current drivers too, so maybe that is why it had a backup button.
I don't update the graphics drivers every time they bring a new one out though. I don't game so if the driver is stable I only update a few times a year at most.
There's a program called 'Classic Shell' for giving back the real Start Menu.
It's free, stable as all get-up and you can customize it to look like XP, Vista, 7, etc etc.
The Win X start menu isn't what they hinted it would be.
Install Classic Shell and feel right at home ...
After you clone recover, I'd run the full suite of DISM commands to see if your libraries have that typical fouled up thing going on.
The upgrade should go smoothly if your 7 or 8.1 library stores and registry are solid.
Responded to, your option was basically less than a third of getting a license here, and I'd need 2-3.
