One more tip. If you guys are like me, you like having stuff in certain places and when new versions of Windows come out, the
rearrangement thing can be daunting. So here's the tip: Right clicking on the Start Menu icon gives you ALL the familiar quick
access buttons to stuff you probably use a lot like me; e.g. control panel, computer management, programs and applications.
You can also search "My Stuff" with magnifying glass and then pin your commonly used buttons either to the Start Menu tiles and/or
the task bar ... which is what I do for my favorite tools.
Good luck with your reinstall John!![]()
Yeah I figurd that out as well as the log off, not sure why reboot wouldn't do the same as log off with a fresh boot.
One other thing, probably good idea to make a restore point as soon as you get 10 to boot initially.
