- Jan 14, 2011
- Gillette, Wyo.
The little , green, resistor lookin things....
With no outputs in, no fuses blowing, the bulb should be dark. The cycling you are talking about is the recharging of the main caps. If the +/- 15 voltage is good, and the backplane fuses are good , I don't think there is anything wrong...
A blown backplane fuse could cause the relay not to work. Check DC offset next time it's turned on...
So how and why would those backplane fuses blow?
You had problems with a bias tranny right?? Check offset on both channels...
From the bias test points on the board, to the respective + speaker posts I get open circuit. Nothing. On the top +15v point, I get +15v. On the bottom -15v point, I get 1.4v. Also, I'm not getting any voltage to the leads that provide power to the meter light-fuses.
With the relay out, youre not going to get anything from the speaker posts, you'll have to test from the "out" test point on the backplane. Check rail voltage on the top of the backplanes also...
Try ground to TP3...
