Resurrected a Customized WOPL 400
With no outputs in, no fuses blowing, the bulb should be dark. The cycling you are talking about is the recharging of the main caps. If the +/- 15 voltage is good, and the backplane fuses are good , I don't think there is anything wrong...
scottonnob
Yeah, dah, of course. Now I understand. There are two fuses on each board. On both boards, the top fuse has continuity, but not the bottom. The bottom has no continuity.
scottonnob
My other problem, however, is that the relay isn't working.
A blown backplane fuse could cause the relay not to work. Check DC offset next time it's turned on...
scottonnob
From the bias test points on the board, to the respective + speaker posts I get open circuit. Nothing. On the top +15v point, I get +15v. On the bottom -15v point, I get 1.4v. Also, I'm not getting any voltage to the leads that provide power to the meter light-fuses.
scottonnob
Sorry, 0 offset, both channels.
With the relay out, youre not going to get anything from the speaker posts, you'll have to test from the "out" test point on the backplane. Check rail voltage on the top of the backplanes also...
scottonnob
Okay, one more time. Be right back.
scottonnob
From GND, TP3 to OUT on the backplane boards, I'm getting, believe it or not, left 66.8vdc, right 12.94vdc.
