Darc, I gotta shit, shower and shave for date night..I'll be watchin from the bar, you're in good hands with Joe..
Leave red on the left, black on the middle..
Hi Darcy
For Q1 you should get readings approximating these. Q1 is NPN. Q1 pinout is B-C-E when looking at the face of the part with leads pointing downward.
B+C- means you plus probe is on B or base and your minus probe is on C or collector. That is the nomenclature below:
B+C- = 604
B+E- = 605
C+E- = 745
C-E+ = Open
B-C+ = Open
B1E+ = Open
Record your results in a list like this.
Australia
Hi Darcy
B+C- = 604
B+E- = 605
C+E- = 745
C-E+ = Open
B-C+ = Open
B1E+ = Open
Thanks joe, im starting the testing now
Then after getting that list, do the same for the voltage reference VR1
For VR1 you should get readings approximating these. VR1 pinout is R-A-C when looking at the flat face of the part with leads pointing downward.
R+A- means you plus probe is on R or reference and your minus probe is on A or anode. That is the nomenclature below:
R+A- = Open
R+C- = 789
A+C- = 605
R-A+ = 672
R-C+ = Open
A-C+ = Open
Good luck! Power off for all readings. Diode scale for all readings.
Australia
Results: (For Q1)
B+/C- =554
B+/E- =560
C+/E- =1280
C-/E+ = Out of range (1)
B-/C+ = Out of range (1)
B-/E+ = Out of range (1)
Australia
Results: VR1
R+/A- = 225
R+/C- = 231
A+/C- = Multimeter Beeps (Like when you touch probes together)
R-/A+ = 224
R-/C+ = 231
A-/C+ = Multimeter Beeps
I recommend you cut out VR1 since it does not work anyway and retake the measurements on Q1. I want to see whether it is walking wounded or not. I am suspecting it may be but cannot tell with VR1 affecting the circuit. You are dead in the water until this is fixed anyway so it really won't put you in any worse of a situation.
Australia
Ok Will do
Australia
The Measurements on Q1, power off with diode scale? I have de-soldered VR1
Australia
Re-take Measurements of Q1 using diode test on DMM
B+/C- = 556
B+/E- = 561
C+/E- = 715
C-/E+ = Out of Range
B-/C+ = Out of Range
B-/E+ = Out of Range
** C+/E- went from 1280 to 715 after removing VR1
B+/C- = 556
B+/E- = 561
C+/E- = 715
Q1 Appears OK which is good, VR1 is dead tho
