I still have that zener diode D80 lifted, should I put it back on? Forgot about that
Not necessary, a non-essential part. What are you measuring now on the collector(tab) of Q1 (MJE15032)? Should be ~+100V
Reconnected D80Not necessary, a non-essential part. What are you measuring now on the collector(tab) of Q1 (MJE15032)? Should be ~+100V
OK good, you have a voltage feed. Now how about the 20K resistor in location R85, both endsMiddle Pin of Q1 101 volts, sorry Joe I have no idea sometimes
Is R85 any good? You will be able to tell because it will be on the upper side of warm
Measure it with the power off...is Q1 any good? BCE measurements?R85 Looks slightly darker than the other one, I don't think its gone
I finally found where my email notifications were going, should be able to reply faster now
R85 Measures 24 ohms, Rises to 25 Ohms after a minute or so. R85 Measures 0 volts with power off.
As for Q1, do you want me to measure it in volts or ohms and with power on or off?
R85 should measure 20K, not 24 ohms.
Measure Q1 with the diode scale on your DMM
Q1 is an NPN transistor. You are going to diode checvk each junction in that transistor, power off, Positive lead on pin 1 ( if the front is facing you with the pins down , far left is base) negative lead on pin 2, then pin 3. Should have around .600 volts DC on diode check...
