grapplesaw
Got it in 1 D2!!!!!!!!!!!!!!!!!!!!!!!!!
Mo pics...
Actually Glen, I could have stayed with the stock #16 as this is a 240volt model. The new chassis has a wee bit more room in it and I was finding out how large we could get with the wire. Some customers want bigger wire...
After some testing, maxed out into 4 ohms with a #16 mains cord voltage drop went from 121.3 to 118.7....
Thank you for the info Lee on the BR
Did you use smaller supply line to the 240 transformer input? the amperage should be cut in half for the higher voltage. Did the 240 transformer put out a higher rail voltage in the end?
I will have to see if any of mine are dual voltage.
Glen
