62vauxhall
- May 14, 2014
- Southwest Kootenays BC
Hole #4, blue, base of Q11....the base of Q11 DOES NOT have any busbars on it. ....
Done.
Hole #5, black, base of left channel bias transistor Q6
Drilled holes or built a fixture?....CARVER!!!! What did the factory use for a fixture??? I know you're out there!!....
Did you drill holes in the board for the wires ir did you build a fixture ro help you with sildering?? The other was to flush Bob out when he's lurking...
Hole #6, kinda pink. goes to the emitter of Q13, left channel positive drive
Correct....
K.. Hole #8, grey, collector of Q12, left channel negative drive driver..
K, Hole #9, yellow, collector of Q14, left channel negative drive ......
