- May 14, 2014
- Southwest Kootenays BC
Seems to be that like others, I was led to this forum while searching for causes of problems with Phase Linear 700B amplifiers. The example I have was made on May 2, 1974 or at least the PC board was. Serial number is 574-0878. I've had it since 1990 and early on, used it to power 2 Peavey PA speakers in a band rehearsal room. It was never pushed and the meters barely moved.
Within the first 10 years I had it, it was taken for service 3 times during which, some output transistors were replaced. What's in there now are (10) RCA MJ10534 (made in Mexico) and (2) RCA 410 for the right channel. The Left channel contains (10) Phase Linear XPL909 and (2) RCA 410.
For 10 years after it's last repair, it sat unused in a closet. In 2010, I thought to put back into service powering a home stereo but I anticipated it was in need of some lamp bulbs. With no source or speakers connected, I plugged it into AC but immediately upon turn on, there was a spark and flash from the inside. It went to a tech for repair and the bill was $25 parts and $135 labour. The part was (1) Mallory 10,000 Mf 100V capacitor in the right channel. I asked why only one and was told that's all that was needed.
The amp seemed to work satisfactorily for a couple of years but from time to time, a "snap" sound would be heard. It occurred randomly and I could not tell if it was coming from the speakers or if it was something arcing within the amplifier. The last occasion this occurred, the "snap" was a little louder and the right channel quit. I first examined the fuses, found the uppermost right channel 5A supply fuse blown and put the amp back in the closet until now.
Would there be an informed guess as to what causes this fuse to blow? I'd like to have it work again but cannot afford the $75 per hour or higher labour cost.
My diagnostic ability is rudimentary and I have nothing but an analog multi meter for equipment. However, I can solder and comprehend schematic and wiring diagrams somewhat enough to have re-built a tube amplifier and re-capped several tape deck pre-amp boards.
I understand there is now a loaded PC board for these amplifiers. Could something on the existing board have the blown that fuse and would a new loaded board be beneficial? Or is it more likely power transistors again and/or the associated 1W carbon composite resistors?
