Drilled holes or built a fixture?....CARVER!!!! What did the factory use for a fixture??? I know you're out there!!....
Did you drill holes in the board for the wires ir did you build a fixture ro help you with sildering?? The other was to flush Bob out when he's lurking...
62vauxhall
Southwest Kootenays BC
Fixture? As in what am I doing to hold the board in place while soldering?
A plastic container to rest the board on and an alligator clip to hold the wire in place.
Hole #7, was orange, goes to the collector bus bar left channel positive drive....just above where the fused B+ plus wire is soldered in at...
