Hole #5, black, base of left channel bias transistor Q6
Drilled holes or built a fixture?....CARVER!!!! What did the factory use for a fixture??? I know you're out there!!....
Did you drill holes in the board for the wires ir did you build a fixture ro help you with sildering?? The other was to flush Bob out when he's lurking...
Hole #6, kinda pink. goes to the emitter of Q13, left channel positive drive
Fixture? As in what am I doing to hold the board in place while soldering?
A plastic container to rest the board on and an alligator clip to hold the wire in place.
Hole #7, was orange, goes to the collector bus bar left channel positive drive....just above where the fused B+ plus wire is soldered in at...
Was orange? Just to ensure there is no mistake, orange wire to hole 7. It is coming from a bus bar.
K.. Hole #8, grey, collector of Q12, left channel negative drive driver..
K, Hole #9, yellow, collector of Q14, left channel negative drive ......
K, Hole #10, brown, emitter of the left channel bias transistor Q6...
