62vauxhall
- May 14, 2014
- Southwest Kootenays BC
K, Hole #10, brown, emitter of the left channel bias transistor Q6...
Done.
Jer, shipping label sent..
K, Hole #11, purpler, emitter of Q12, left channel negative drive, driver...
K, Hole #12, negative(ground) ftom left channel signal in. Make sure only the negative wire and NO SHIELDING gets soldered here. The shielding is attached at the copper plate and that should be the only connection for it.
I may have screwed you up on this earlier come to think of it.....At the copper plate the signal ground and the shield should be soldered together on the copper plate. And only the ground wire to the board. Take a pic of the pots right quick...
Scrath that. That's hpow we do the White oak board. The shield should be on the board in said #12 hole, signal positive in hole #13...
Ok, I have to get up early tomorrow Gary. On the right channel side of the board starting on the left, #1 is red, unfused B+ to the positive terminal of the power supply upper cap.
I'll run through the rest in the next post...
Done, but i have to drop this for now too.
I live in a condo building and an elderly neighbour lady apparently returned yesterday from a few days in the hospital. She is very confused and wandering the hall, trying to let herself in to different suites including mine.
I've got one of the strata council members with me and the two of us, will stay with her until son/daughter or someone can be contacted.
Can't let her be alone right now, I'm sure she's very scared.
Will post again in the morning,
#2---white/ green/black stripe....collector bus bar positive drive right channel..
#3----red, collector, bias transistor, Q6 right channelk..
#4---blue, base of Q11, right channel
#5---Black, base of bias transistor, Q6 right channel
#6----Brown, emitter Q13
#7, orange, collector bus bar, positive drive right channel
#8---Grey, collector Q12, negative drive, right channel
#9---White, chassis ground, middle of right 3 terminal strip..
#10---yellow, collector of Q14
#11----brown, emitter of bias transistor Q6, right
#12----Purple, base of Q12, negative drive, right channel
#13---signal ground, right
#14 signal positive , right...
We'll power up tomorrow if ya think it's ready...
