- Jan 14, 2011
- Gillette, Wyo.
I'm sorry Gary, we're confusing you. On the factory set up that #16 silid wire does tie everything together to ground, in a WO conversion , the ground plate is isolated from chassis ground and grounded through the driver board. If you cut the #16 bare wire yours will also be this way. Those 220K resistors keep those small caps on the direct/normal coupling switch discharged when nothing is plugged in. The factory driver board is also grounded to the chassis by rhe small white wire coming off the board, and the rca's are grounded to the board by their ground wire in the shielded pair.
The White Oak boards treat this whole grounding scheme a bit different as its ground wire goes to star ground insted of the 3 terminal strip on the right. Cut the #16 bare wire between the D/N switch and copper plare, cut the #16 bare wire between the D/N switch and the speaker ground posts, that should do it...
