- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
I saw the Jer. I have no bucks so maybe just a look over and checking the bias would probably be it unless you have other not super costly ideas besides the face plate and fuses. Maybe you could tinker with the meters a little more. A couple times when I turned her on, they would swing and drop to where they should be. Not sure what the issue is with them. I know that Sally's meters seem to react a lot more then Blackies, more sensitive? I like that a lot indeed
I am amazed the Sally NEVER gets hot... I mean NEVER no matter how loud I crank her. You built one hell of a majestic amp in Sally Jer, every hat I own is off to you!!! I think the fans on her will be used for Blackie as Blackie does get angry sometimes LMAO and her temp comes up quick when she is firewalled
That IS something, eh? Wonder if Joe or Lee can expound on it a lil ... maybe the FC design doesn't dissipate as much in operation as the QC does?
