PL 700 II REPLACEMENT MAIN VOLUME POTS
Gepetto,
One more question....
Are the new Pots hooked up exactly as the originals?
I'm not one that has the knowledge to understand Schematics but I can replace parts.
I really don't want to ruin my amps.
Skip
Gepetto,
Skip
Yes, will have the same 3 terminals as the originals. Just transfer the wiring 1 for 1 from the originals.
Gepetto,
Skip
Skip, are you having issues with your WOPL's?? Contact me, they are still under warranty.
Thanks Perry but, I don't consider this as a warranty thing on the build.
This is a normal wear & tear thing that happens with an original part.
It's all about keeping people OUT of the amp. It's yours so IF you decide to go into it, your choice..... I can't warranty anything where guys can just go in and work on shit.
Glenn, the 700 Pro were built with very nice Alps 50K attenuators that easily come apart for cleaning and greasing. I wanted to keep those. Because I'm using it biamped, I wanted to match that input impedance on the other amps.
I have yet to really understand input impedance. I've read about how to check it, and Joe has commented on it and how PL used a high input impedance probably because people were using tube preamps. My understanding which may be faulty, is that total resistance of the attenuator pot affects input impedance. Hopefully Joe will comment on this.
I want to try the CJ PV6 with the WOPL but have not been able to make myself do it.....yet.... It sounds so damn good the way it is with the Forte F44 that I am like... Do I really want to change it!
Not trying to be an ass, but the FTC would disagree if anything ever went to court. It's expressly forbidden in US law to void or deny service on a warranty simply because someone else was in it. You are required to prove that what they did caused the problem . . . (IE, in this case, for example, if the user changed a pot and then the outputs in a channel blew later, warranty is going to be enforced.) It's the Magnussen-Moss warranty act . . . and I have had to use it on Netgear for trying to void my warranty on a network switch simply because I told them I verified the dead power supply with a DMM.
Hopefully, all here play friendly enough for these types of issues to never come up . . . and folks who do go into things know thier limitations.
FWIW . . .
"It's all about keeping people OUT of the amp. It's yours so IF you decide to go into it, your choice..... I can't warranty anything where guys can just go in and work on shit."
Perry, we already talked about that the first time I went in to Deox & Fader lube the pots.
It would be asinine of me to ship my 700 II amps to and back to have pots cleaned & lubed.
I'm not a hacker when it comes to de-soldering and re-soldering things. Me does have some crazy good soldering skills.
Not wanting to start an argument, just want beautiful music again.
Thank you again Perry,
Skip
I'll try Lee but, I'm an asshole oh de oh....
It's just the Lineman in me coming out again.
Had the Input Attenuators been replaced on the build we wouldn't be having this conversion.
Perry, you built it and have that choice... so be it.
Warranty Voided.
By the way, I'm not one of those "people".
Worked as a Certified Micro Modular Solderer, before the military, and built the PC Boards, Control Equipment and Switch gear for the Dragon Missile System.
Certified to Military & Aerospace grade Soldering while @ McDonnell Douglas Aerospace in Titusville, FL.
I can replace an Input Attenuator, it's not Rocket Surgery nor is it Brain Science.
Here's a quick test for the pot....
After doing the cleaning of the pots turn the Input Attenuators to full Counter-Clock-wise position.
Play some tunes and slowly turn up the volume on the preamp. If you start to hear the tunes playing out your speakers... it may be time to consider replacement of the offending the Input Attenuator.
After I replaced the pots on the amp, total silence bliss even with the Preamp at full splash.
You can also void the warranty on my other Clair Bros 700 as I'm replacing those two too.
Sorry for the rant Phoenix, Lee, good day.
Skip
Cool beans here.
Me too, there's times when I'm on the rag and had a couple too many Frosty Beverages.
Must be an age thingwith me.... Naaaah.
Skip- did you work at McDonnel-Douglas Titusville in a building that was near Kennedy Space Center? A coworker had spent time there. Knight's Armament is in that building now- I have some of their "products"...
Warranty Voided.
Skip
Not to stir the pot, but as per US law he does *NOT* have that right, whether he built it or not . . . as cited above. You may have just willingly surrendered your warrantly, but legally, he had no leg to stand on in light of what you did. At *MOST* he could have voided warranty on the pots (which it sounds like he didn't replace anyhow).
(I stress this since a lot of folks fall for this, and are taken advantage of my many manufacturers all across the country. How you two choose to handle this isn't my issue . . . )
