Joe, thank you! Yes! Now I'm starting to understand this a little better.
Glenn, this is why I matched the 700 Pro 50K attenuators on my other 2 WOPLs.
I noticed the "gain structure" wasn't equal between the 700 and a 400 when they were built exactly the same other then the attenuator values. The 700 was louder at all volumes and this caused a balance issue in the biamped system. Building all the amps exactly the same including the attenuators fixed this issue.
I remember Joe saying he prefers no attenuators at all in circuit, but forget what value he suggested if one must use them.
This started my quest to learn more about preamp output impedance and amp input impedance, but I got hopelessly lost on the other forums because I lack understanding of much of the fundamentals.
There are numerous threads on other sites about this, particularly about preamp output impedance, and "rules" are often stated.
