George S, years ago I had a similar head-scratcher when I bought a previously-enjoyed HP Blackbird 002. It was an unscarred beauty visually, but it wasn't running as reliably as you would expect from the build quality? Finally, I took a hint when the computer crashed when I brushed against the power cord...on the way to the fridge?
The power cord was heavier than normal, and the connection to the (loose/goofy) wall socket just seemed iffy. I went to the nearest Home Depot & picked up a "commercial grade" 120v/15a outlet, and replaced the sloppy tired original. Voila! I could now hit the power cord all I wanted, and no worries at the computer. Cost of the fix to cure the 'flaky computer'? < $3.
Here's an
example of what I upgraded to, available as soon as today. NOTE: 99% of houses are originally built with 'residential/homeowner grade' outlets. Definitely more affordable, especially when you are installing 40-50+ outlets in a typical home. But the physically busier the outlet, the shorter the lifespan.
On the other hand, a commercial-grade outlet in the same spot is estimated to last up to 100 years.
FWIW, if you are a 'belt & suspenders' kind of guy,
here is the testing that a hospital-grade outlet has to pass to be certified.
Lastly, the guy in this video cuts apart a residential and a commercial outlet, and shows you the physical differences that you are paying for:
What the heck -- if the outlet you are using is loose/tired, then in the interest of troubleshooting why not try a fresh plug & see what happens?
Good luck!
