- Jan 14, 2011
- Gillette, Wyo.
Going to parallel the contacts?
Been thinking about it. I did both of the PL2000 S2 preamps that way. What's your thoughts Lee? Any issues doing that on the amps?Going to parallel the contacts?
That's what I do. Last one turned on and first one turned offI almost wish it was like a 400 and had no switch. Sure would simply things. Oh well, it'll be left on and switched by a power strip.
Well, I do have about 40 feet of old arc welding cable left over from the last set of jumper cables I made! I'd have to do some major rewiring of the house, wife Would Not be happy. Think I'd better stick with the standard layout with a switch. To tell the truth, my two 400 WOPLs don't often get a workout.George I built a 700 once where I brought the AC in just below the terminal strip..
I agree that bringing the supply AC in by the transformer does make better sense doesn't it? Like a 400. Well, the 700 is what it is. A lot of extra work that could have been resolved with a taller chassis.
Hmmm...Yep, a roomier chassis would be a blessing...
??Or...
It was completely random George, but it seems a majority of the hotties were made by Bob's stoner brother when he was the transformer winder...in the Ser I's...
Some Ser II's like Darcy's were 108...
Hey, I've seen you reference using batteries? Are you using some sort of solar power system?108.7 at the old place, about 105 here as the mains voltage is lower.
