Wheel-right
Hey, I had one those, it was the Levi's special with blue exterior and upholstery of Levi denim blue. 6 cylinder, 3speed manual with overdrive, not a nice driving car but when it's all you can afford...
I worked in engine assembly in the 70's at American Motors building the 232 cubic inch 6 cylinder. I'm surprised they even ran after watching some of the clowns smashing crankshaft into the bearingsHey, I had one those, it was the Levi's special with blue exterior and upholstery of Levi denim blue. 6 cylinder, 3speed manual with overdrive, not a nice driving car but when it's all you can afford...
I have a Gremlin X fast ratio power steering box in my Jeep. Just need to find the small one in the amp!
It always seems to be something simpleSo found the issues. These old Dell power cords are funky. They came with the XPS 700, 710, or 720 with the 1000 watt power supply. I've got 2 XPS 700s and 2 720s and they all suffered from intermittent restarts. Now I know why. I can slightly move that cords end plug and watch the voltage drop.
Second issue is the Radio Shack True RMS meter. It's junk, gives a totally different result each time I take a reading. I'll keep the leads and new batteries, rest is going in trash
Going to order some new cords, and peruse the bay for another Fluke and a decent Simpson 260 or 270 analog meter.
The 12 VAC is right on the money if I slightly twist the cord end to make good contact.
Yeah man. That Fluke 77 BN I have is the same model I used throughout the end of my military career. Accurate and bullet proof. I just put in a offer for another.I had a thread a while ago contemplating meters…
I got the Fluke 87V and have already been through a set of batteries. It is serving me well.
I'm looking at learning highly accurate FM tuner alignment and I'll need two alike meters and a big dial analog.
Trying to keep the wiring elevated between the back plains and control board. All the AC in one bundle, B+ and - and output grounds in another. I'll have a smaller bundle somewhat across the top with meter wiring that catches that candy cane colored AC switch wiring.Quite a bit different.....
