- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
Measure R85, one lead on each side..
R85 is 20.5 ohms
Should be 20,000 ohms...
So, do you think that is 20.5K ohms?
On the diode test of Q2, what does 1 represent on your meter?
If I put it on the lower scale/range on dmm, then it says out of range, 200k scale/range is needed to get the 20.5 value. If I put the dmm on the 2M range I get 0.020
