Sorry guys, I measured the Picos wrong, thanks Lee for informing me of the correct procedure
** The Top Pico on the right hand side backplane measures high, I had to turn my multimeter up to 200k range to get a reading. The others I was able to measure on the lowest range.
Soldering a new one amp pico over the old one. If you dont have a solder sucker DO NOT desolder and pull the old one. Just lay the new one next to the old one and solder in,. Joe may have a trick of using a very small (1/8 watt) 1 ohm resistor to finish trouble shooting if you cant find a pico in Oz.
Pico fuses are available from WES Australia ,02 9797 9866 .A web search will give online services/catalogue. The one amp picofuse is listed as part number PF1
What does Darcy have on hand would be a good start? The value is not super critical.
Got one of these but I can go to Jaycar Electronics tomorrow and get other stuff, maybe not a pico though. Need to replace a couple of tiles on the roof of the house. tomorrow morning.
Ok, I do have a solder sucker, do you want me to remove the blown pico and solder that resistor I have in its place?
Just tack it on top of the existing Pico as Lee suggested Darcy. Till you complete your debug. This is just temporary until you can get a fuse replacement and to continue to see if anything else is wrong or not.
Ok I'm onto it.
I still have that zener diode D80 lifted, should I put it back on? Forgot about that
