- Jan 14, 2011
- Gillette, Wyo.
Younger Brother Is  Simon Posford and Prometheous, Shpongle is Simon Posford and Raja Ram...
			Cool, I'll check it out.Younger Brother Is Simon Posford and Prometheous, Shpongle is Simon Posford and Raja Ram...
Yeah Joe. Even with proper tolerances given, it still comes together awwwefully close! They sure didn't give ya much room to work? The negative meter lug barely clears and that busbar with the new caps sits pretty close to the positive stud. But, it WORKS.Glad to see you moved the hold down plate to the outside hole which nests it against the chassis sidewall. Provides more meter clearance.
You can't beat that beautiful face of a Phase Linear. Nothing today even looks HALF as good. And in this day and age you think something WOULD? But let's agree here that after Joe's stuff get's in it; there's not much "Vintage" about it excepts it's looks.Your pictures are very clear and full of info for future builders. I have a 400 I bought new in the ‘70s that is still original. Some day I would like to overhaul it. I also live in Saint Louis so it’s nice to know there are others locally who still appreciate vintage equipment.
For the close ones, I slide some of those large nylon washers between the faceplate and the chassis ears. It moves the faceplate out just enough to make me think there will be no collisions between metal parts of different voltage potentials...Even with proper tolerances given, it still comes together awwwefully close!
I don't know if I'd like that 'GAP' per se'. Perhaps; should the market ever warrant it; Joe may make available a new chassis for the 400 that's a tad deeper; to compensate for the better components. I doubt it, since the 700B is the better choice there and a hot ticket item, but you never know? Some people LIKE to crank their WOPL400's to mach-10. So I could see a better power cord, etc. in it's future/ (shoulder shrug).......For the close ones, I slide some of those large nylon washers between the faceplate and the chassis ears. It moves the faceplate out just enough to make me think there will be no collisions between metal parts of different voltage potentials...
It has been fully designed, just not fabricated. Your clearances are fine based on your photos.I don't know if I'd like that 'GAP' per se'. Perhaps; should the market ever warrant it; Joe may make available a new chassis for the 400 that's a tad deeper; to compensate for the better components. I doubt it, since the 700B is the better choice there and a hot ticket item, but you never know? Some people LIKE to crank their WOPL400's to mach-10. So I could see a better power cord, etc. in it's future/ (shoulder shrug).......
Nothing wrong with that audio test (well, maybe it was too short...).
Yup! No dissagreement there! You know where THAT’S headed?.........Quasi on the low end....tsk, tsk...
Yep, gonna be fun watching you do all 8, you're fucked now...
