Had some noise issues with Cathy. I had not adhered to the star ground notes in this one. I had 3 separate grounds going to the chassis and one from the input ground to the ground bus. I was sitting at 2.5 MV on both channels. After cleaning up the grounds, I still had over 2 MV. On a series I the output wires leave the bus on the bottom. I unbundled the outputs, B+.B-, and the shielded pair kept them away from each other, and added another inch to the board standoff, lots of room to do that with Ser I meters. It was very audible through the horns, the dreaded 60 hz hum. Residual noise is now 420 uv....I'll take that any day with the backwall still stuffed with sockets.
Had a biasing issue with the right channel. Drove me nuts for an hour or so, traced it to a loose driver pin socket. Removed the driver, cleaned the pin and socket and pinched the socket tighter, holds steady now..
Back on the horns...love the black hole for noise...If you can't hear any noise through these horns at idle, the amp is truly quiet.
Waiting on some snubber caps for the Power supply caps as per Scott's request then she'll be on her way back.
