You have to use the right kind of grease, wait for it...
Elbow grease!
			Elbow grease!
It’s your amp so I can’t tell you what to do with it. Better to use the ruler test outlined in the instructions. Prevents parasitic pickup if you get leads too close to chassis. If you use insulator, I have seen too long leads plus insulator work initially but fail years or month later when the leads pierce throughStray thought..
Die- cut kapton insulator sheet between the backplanes and chassis.
Yes, I know there’s no excuse for sloppy assembly work, but clearance is tight in that area. Prevent a spark gap?
As I said, no excuse for sloppy assembly work!It’s your amp so I can’t tell you what to do with it. Better to use the ruler test outlined in the instructions. Prevents parasitic pickup if you get leads too close to chassis. If you use insulator, I have seen too long leads plus insulator work initially but fail years or month later when the leads pierce through
And that’s the whole point! I also hope that some 13 year old geek gets trapped by them and starts a career in electronics, learns enough to shut down Skynet and keep the Terminator in its own time.Mark, I just want to say thank you for all the great videos you've created to help everyone. Me being a newbie I'm very grateful for you showing what can be accomplished and for you spending so much time producing them.
But it works even on a 63 year old like me to, just got done installing a Watts Abundant DCP relay and a new set of power caps from White Oak and they both worked first time and now the 400 Series One sounds way better with the 2000 Series Two. Next up a new a White Oak control board...And that’s the whole point! I also hope that some 13 year old geek gets trapped by them and starts a career in electronics, learns enough to shut down Skynet and keep the Terminator in its own time.
Hacking on the rectifier and input jacks today.
Mark, your idea is sound. Just be aware that PL used some very high quality wire in their single coaxial cable. The wires you have selected are probably the lowest quality wire that China is able to source for the American market. Radio Shack used to be a good source of short cable spools repurposed from larger runs of high quality Belden wire.A question about the input jacks/sensitivity control/control board connection.
I want to clarify this before proceeding with the next video...
So.. kosher or no?
Yes- I bought some higher quality cables for this.Mark, your idea is sound. Just be aware that PL used some very high quality wire in their single coaxial cable. The wires you have selected are probably the lowest quality wire that China is able to source for the American market. Radio Shack used to be a good source of short cable spools repurposed from larger runs of high quality Belden wire.
I'm not saying it won't work perfectly, just be aware the size and quality of those RCA cable wires will not compare favorably with PL wiring.
I use Navo's Milspec coax.... GREAT SHIT!
I can’t justify $270 for a half-meter cable pair.Between that and the Cardas input jacks, there's no room for anything funky.
Ah, just put it on "stun".I'd rather burn out the 15w built-in than risk the Phaser
Bad Finger...........I only had one guy stick his fingers back there
