Howdy Mark; I need a 16mm projector. Ebay is my only option here in boonie land. Recommendation's?
My wife was a high school teacher & I grabbed a bunch of cool films when the school was just dumping them.
A lot of early American industry stuff like mining & steel production.
Thanks Brad
Oh...How's the health?
Bell & Howell 1500 series- they're indestructible tanks- except for one thing- the worm gear! Every one is guaranteed to be cracked, and it's a royal bitch-in-heat to replace. They're (nylon?) on an aluminum core. You can get replacements, but then you need a set of bristol wrenches and retaining ring tools. Funny that the replacements are much higher quality than the originals. When you get them broken down that far it's a good idea to clean the shutter cam and the shuttle (the pull-down claw) and relubricate. After all that, make sure the shuttle retracts fully to disengage the sproket holes or your film will just go up and down at the gate while the sprockets are trying to pull the film forward.
LOTS of adjustments.
I've replaced the worm gears on three projectors. Masochism
can be an art...
Avoid the 2500 series- plastic cases, can't get replacement case parts and you don't wanna super-glue them together if you need to replace the drive belt (another bitch-in-heat scenario!).
Eiki bought out B&H, they're slot-load, reasonably reliable (or so I hear, no experience with them...). I have a hard time expecting a slot-load to be unthreadable in mid-reel.
Another goodie is the Singer/Graflex 16, but don't run it in reverse- there's no bottom sprocket and the shuttle pulls the film from the sound drum flywheel, hard on the film. It's a semi slot-load.
Photo: severely cracked worm gear.
Photo: how far you have to breakdown to get to the worm gear.
Health has been great! A little concern over retinal edema, no worries. A1c has been <7% consistently for the last 2 years, but the pharmacist bitches at me about not refilling my Rx on time. Still need to quit the tobacco.
