- Jul 6, 2010
- Broken beyond repair but highly affable
The USB external drive was good to go without the driver disk, XP just assimilated it happily and the transference has begun!
The Evo is back and loaded with XP Pro and although my friend say it has a number of swollen caps to his knowledge it was working great.
Two things I am still looking for:
2 512 MB SDRAM modules, 133 MHz preferred for a Dell GX-240 (the early i845? chipset made to run on SDRAM...I'm not going to get goofy on it but XP on it (2000 is on right now) and finding the ATi Rage 128 dirver for the low profile video and it will see duty in the workshop.
I have another Dell, Dimension 8250...the case is really neat but the motherboard is that horrid RDRAM one. It uses a convetional ATX PS so if I could find a motherboard with 4 PCI and an AGP slot that will handle a decent amount of RAM (like maybe 2 GB or so or DDR type) and SATA perhaps or another large drive or something.
Well, I'm just rambling at the moment but I know what I want, I just don't have it figured out. You don't need to ask right now.
I'd had the Dimension 2350 off line for about an hour now and the files transfer is close to being done for the media files. then some other files.
