If you are going to load win 7 it is best to do a fresh install and of course make sure you buy the correct version for your comptuer either 32 bit or 64 bit. Also run the win 7 compatibilty software on each computer to make sure they will work with it. No sense buying a license if you cannot use it.
The retail version can be installed one one computer then removed from the same computer an installed on a nother computer later on. The
OEM version is pretty much married to the first computer it is installed on.
