THEY"RE HERE!!!!!!!!!!!!!!!!!!!!! SONIPHASE S6
Skratch
Huntley Il.
#41
I didn't use anything, With everything being flat and the amount of screws (15) there was no leaking. I thought about a thin film of silicone and let it dry before putting the hatch on if it leaked but had no leaks
#44
Tryin, doing a lot of phone calls. Field folk and now Steve, looks like we'll be awhile.
#49
I squeezed the seal between the motorboard and the cutout to almost nothing, seemed the right thing to do considering what is goin on in there.
Skratch
Huntley Il.
#51
Yea, Squeeze them tight, all nylon lock nuts and all the lock washers should keep anything from loosening up. The Tee nuts all have been super glued into the motorboard
#57
WOW!!!!!!!!!!!!!!!!!!! Playin with slope, cutoff and tryin to dial em in with the K-Horns------ I think they're going to play very well together !!!!!!!!!
#58
I know the Spec 2 ain't gonna keep up. Had the needles buried on the Spec and had to dial back the Larrt's 700 on the K's. Mark-----it was a wise thing to gather up the Carver beastie, now I have some incentive to build the 1.4KW monster with the white Oak board
#60
Lot of time/frequency issues to deal with. But I think when they get back in the corners with the K's that will all work out.
