BrickbyBrick
- Jul 30, 2022
I have a Fluke 114 which unfortunately doesn't have that capability.Do a quick check with your DVM on diode scale. Check all junctions forwards and backwards including C-E checks in both directions.
What do you have for electronic test equipment?
I took out all the but the bottom row of transistors and the max DV voltage on the bias is +60ma. So it seems that there are some bum transistors in the bunch. Must've been that one leg that was shorted to ground?
