PL400 Build help
BrickbyBrick
#21
Do a quick check with your DVM on diode scale. Check all junctions forwards and backwards including C-E checks in both directions.
What do you have for electronic test equipment?
I have a Fluke 114 which unfortunately doesn't have that capability.
I took out all the but the bottom row of transistors and the max DV voltage on the bias is +60ma. So it seems that there are some bum transistors in the bunch. Must've been that one leg that was shorted to ground?
#24
Well that is a bummer. That DVM capability is pretty key for work like this. It will be a crap shoot trying to figure out which is damaged without that capability. Do you have a friend with a Fluke that has that capability?
BrickbyBrick
#25
I'll be doing more work like this, so it might be time to upgrade. Been working mostly on tube gear and never needed that test.
MusicSteve
Minnesota
#27
I think it has a diode tester. it under the Ohm (sound icon)
Yes
Test/Measurement Functions
Resistance, Frequency (Hz), AC Current, DC Voltage, Capacitance, Continuity Test, DC Current, AC Voltage, Diode Test
Features
Auto Power Off, Auto-Ranging, Over Range Protection, Manual-Ranging, Backlight, Data Hold, Bar Graph Display, True RMS, Battery Door Access, Average Value Mode, Min-Max Value Mode
#28
For a few dollars more than the 77 IV, I would recommend something like the Fluke 179 that gets you true RMS capability as well.
BrickbyBrick
#29
With all the TO-3 transistors out I'm still only getting a reading of 50mV on the bias test point.
Does that seem like another component has failed? Bias transistors?
All other voltages check out fine. B+, B- , 15V + and -
MusicSteve
Minnesota
#30
so The RT board blow the fuse? which one? (+ or -) and what output transistor shorted out to ground? explain inside view, could you mark it w a pic (were on the Rt back board)
Did any other fuse blow? 8a?
BrickbyBrick
#31
No it was the 5AGX fuse that blew.
5 6 7 8
9 10 11 12 Power Transformer side
13 14 15 16
Bottom
It was #6 that shorted. If that diagram makes sense.
I'm double checking the manual but I think that only the 115 and 117 has the diode check. I have the 114.
MusicSteve
Minnesota
#32
5 6 7 8
13 14 15 16
Bottom
Do you have this look at arrow?
MusicSteve
Minnesota
#33
You need at least the Bottom row installed, did mark the #6
MusicSteve
Minnesota
#35
5 6 7 8
13 14 15 16
Bottom
back view? or inside?
MusicSteve
Minnesota
#40
You can now do what joe said 000 is a short (Bad)
and put 4-bottom ones in (update NO)
