- Jan 14, 2011
- Gillette, Wyo.
That or some wire out of a relay or transformer or coil...some of that shit is pretty fine....and solderable.....
			No idea what #6 tippet is?Ya mean something like a #6 tippet?? Any idea on what diameter you are talkin?
The original stuff looks like monofilament of some kind. I like the thread idea, I can put a drop of CA glue on the knots and it should outlast me.Silk thread might be a good option. That’s strong.
Human hair is roughly 0.003 inch.
A single edge razor is about 0.007 inch. (Used those as neck shims sometimes)
Thanks, that was my original thought but had no idea what to look for. Going to try the Tippet and the Silk thread, one of them should work.Hold on, I got this. 5x tippet is .006 inch, 6x is .005 inch, 3x is .008 if Dad's old H. L. Leonard leaders and my spool of 5x tippet material are to be believed. Get to your nearest BassPro/Cabelas/Sportsmans Warehouse, etc. and look in the fly fishing section to sample the spools of tippet material and get the size you think would work best. Dad's old 3X Leonard's feel a little stiff to me but 5x feels flimsier than the monofilament SME used on a 3009 arm I had on a Rek-O-Kut table as a kid in high school. 4x maybe? Try some - at $5 or $6 per spool, you can afford to experiment.
Edit: ignore the tapered leaders, get the spool(s) of tippet material. Cheaper and more of each size.
View attachment 60969View attachment 60970
Should have taken more pictures but there are differences between the one that came on the TT and the stand alone unit. Nothing major but the main bearing housings are slightly different, one is in a brass sleeve and the other a chromed brass sleeve, the chromed sleeve places the bearings further apart, also the wiring is different. The stand alone unit has the normal four wires the other has six wires that includes two separate grounds.
Took me a second but I like it too. Thanks pointing it out - I was stuck on the screw driver set up.Love the pen holder...
A gift from my love, she says I am hard to shop for because I am like a ten year old with a credit card…..lol, so true.Love the pen holder...
Let’s just say I get Christmas cards from Wiha every year.Took me a second but I like it too. Thanks pointing it out - I was stuck on the screw driver set up.
