- Jan 14, 2011
- Gillette, Wyo.
I kinda feel youy pain there Spence...i don't like fuckin with that micrscopic shit either..
Thanks George, that is similar but unfortunately the connector on mine is down in the tube and heavily glued. I have some de-bonding stuff that I am going to try but confidence is low that it will work. If I could figure out how the arm tube attaches to the main body then i could push it out from the inside but so far I have not figured that out.Spencer, this link may help you get that female connector out. Never seen any of these high $ MS turntables first hand. Anyhow, this is how the AR guys do it. I'll be doing my AR-XB sometime soon using this technique.
https://vinylnirvana.com/ar-turntable-resources/ar-diy-do-it-yourself/rewiring-an-ar-xa-tonearm
Glad that you are back...I’m baaack……well sort of.
Apologies for the long hiatus gentleman.
Long story short, major life changes, confusion and general chaos took me away from this great community. Never lost my passion for audio but I had to put it on hold while trying to find my way.
I haven’t done any audio projects for a couple years now and so I thought finishing this one would be a good start to getting back into it.
After reviewing where I was with this, I decided the dual arm project was a little too ambitious for the time I have available, so back to the original idea.
Lee, your Black Widow has been waiting patiently for this day and I have to say it does not disappoint.
Thank you, I have lots to catch up on but it’s great to see so many old and new faces here.Glad that you are back...
Now I gust need to make time to mess that work bench up again, lol.
The cart came with the Widow from Lee.What's the cart?
Lee, with just a basic setup and just running through the stock Carver test system, I was really impressed. I just set the overhang, set the tracking at 1.5 and the ant-skate at 1.5 and dropped the nail. Wow, crisp, clear, good channel separation and excellent tracking. I have a second BW arm and base that I bought for a backup or possibly the dual arm mod because I lost confidence in the Micro arms. Dual BW’s would be sweet, lol.Glad to see the Widow found such a home....
Found the specsI'm curious because of the ultra low mass of that tonearm. I almost bought one years ago to use on my Wrek o Kut but didn't......
The silicone damping system is worth using IMO, I have the KAB one on my Technics and and have an Audiocraft tonearm that has it too.
Not that I remember Lee but that was a long time ago and i have slept since then, lol.Was there an extra cart?? Seems i had 2...
