Northwinds Veteran and General Yakker Jun 2, 2015 #21 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #21 The two green ones Joe? One has a black outer sheath on it. Do I leave the other black one alone?
Northwinds Veteran and General Yakker Jun 2, 2015 #22 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #22 Gepetto said: What is the part number marked on the bridge rectifier? Click to expand... NTE and looks like 963D
laatsch55 Administrator, Staff member Jun 2, 2015 #23 Joined Jan 14, 2011 Messages 75,327 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Jun 2, 2015 #23 The two black ones, they come from the transformer secondary windings. Insulate them after desoldering...
Gepetto Administrator Staff member Jun 2, 2015 #24 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #24 Northwinds said: The two green ones Joe? One has a black outer sheath on it. Do I leave the other black one alone? Click to expand... The 2 black ones attached to the bridge where it is marked "AC"
Northwinds Veteran and General Yakker Jun 2, 2015 #25 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #25 I don't have a soldering gun handy, can I just snip them off close to the solder joints and tape them off?
Gepetto Administrator Staff member Jun 2, 2015 #26 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #26 Northwinds said: NTE and looks like 963D Click to expand... That number is not ringing any bells Ron, you sure of that?
Gepetto Administrator Staff member Jun 2, 2015 #27 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #27 Northwinds said: I don't have a soldering gun handy, can I just snip them off close to the solder joints and tape them off? Click to expand... Yes, very close to the tabs so you don't loose much wire length.
Northwinds Veteran and General Yakker Jun 2, 2015 #28 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #28 Gepetto said: That number is not ringing any bells Ron, you sure of that? Click to expand... Here you go Joe Ok, snipped and wire nutted, did I do it right?
Gepetto Administrator Staff member Jun 2, 2015 #29 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #29 Northwinds said: Here you go Joe Ok, snipped and wire nutted, did I do it right? Click to expand... Yes, looks fine Ron. I believe the 963D is the date code of the part, not the part number.
Northwinds Veteran and General Yakker Jun 2, 2015 #30 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #30 I don't see any part number unless it's on the base, that's the only marking visable on the sides and all I see is AC on the top
Gepetto Administrator Staff member Jun 2, 2015 #31 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #31 Northwinds said: Here you go Joe Ok, snipped and wire nutted, did I do it right? Click to expand... The NTE bridge is definitely a replacement. The plastic case is a dead give away for an under rated bridge. Probably blew because of (too low of a) voltage rating however.
Northwinds Veteran and General Yakker Jun 2, 2015 #32 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #32 I tried unscrewing the phillips head but it only comes off so far and I did not want to risk messing something up in the tranny?
laatsch55 Administrator, Staff member Jun 2, 2015 #33 Joined Jan 14, 2011 Messages 75,327 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Jun 2, 2015 #33 bad self tapper....reef it outta there...
Northwinds Veteran and General Yakker Jun 2, 2015 #34 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #34 laatsch55 said: bad self tapper....reef it outta there... Click to expand... Ok, it's out, no part number on the base
laatsch55 Administrator, Staff member Jun 2, 2015 #35 Joined Jan 14, 2011 Messages 75,327 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Jun 2, 2015 #35 Not real proud of it were they??
Northwinds Veteran and General Yakker Jun 2, 2015 #36 Joined Mar 18, 2013 Messages 7,572 Location Coventry, CT Tagline Fondler errrr... fan of all Nav's avatars Jun 2, 2015 #36 Well they did brag "assembled in China" on one side...
Gepetto Administrator Staff member Jun 2, 2015 #37 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #37 Northwinds said: I tried unscrewing the phillips head but it only comes off so far and I did not want to risk messing something up in the tranny? Click to expand... And then stops or just spins? Hoping the PO did not put too long a screw in there and jammed it into the windings of the transformer. Well your fuse test should tell you that.
laatsch55 Administrator, Staff member Jun 2, 2015 #38 Joined Jan 14, 2011 Messages 75,327 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Jun 2, 2015 #38 Whoopee....not you Joe..Ron...
Gepetto Administrator Staff member Jun 2, 2015 #39 Joined May 15, 2011 Messages 14,267 Location Sterling, MA Tagline Old 'Arn Enthusiast Jun 2, 2015 #39 Northwinds said: Well they did brag "assembled in China" on one side... Click to expand... Probably a knock off NTE sold on Ebay
laatsch55 Administrator, Staff member Jun 2, 2015 #40 Joined Jan 14, 2011 Messages 75,327 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Jun 2, 2015 #40 SHOCKING!!!!
