Looking for a working early PL 400 Control board
#21
The two green ones Joe? One has a black outer sheath on it. Do I leave the other black one alone?
#23
The two black ones, they come from the transformer secondary windings. Insulate them after desoldering...
#25
I don't have a soldering gun handy, can I just snip them off close to the solder joints and tape them off?
#30
I don't see any part number unless it's on the base, that's the only marking visable on the sides and all I see is AC on the top
#31
Here you go Joe
Ok, snipped and wire nutted, did I do it right?
The NTE bridge is definitely a replacement. The plastic case is a dead give away for an under rated bridge. Probably blew because of (too low of a) voltage rating however.
#32
I tried unscrewing the phillips head but it only comes off so far and I did not want to risk messing something up in the tranny?
#37
And then stops or just spins?
Hoping the PO did not put too long a screw in there and jammed it into the windings of the transformer. Well your fuse test should tell you that.
