- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
The two green ones Joe? One has a black outer sheath on it. Do I leave the other black one alone?
			What is the part number marked on the bridge rectifier?
NTE and looks like 963D
I don't have a soldering gun handy, can I just snip them off close to the solder joints and tape them off?
That number is not ringing any bells Ron, you sure of that?
	Here you go Joe
Ok, snipped and wire nutted, did I do it right?
Here you go Joe
bad self tapper....reef it outta there...
I tried unscrewing the phillips head but it only comes off so far and I did not want to risk messing something up in the tranny?
Well they did brag "assembled in China" on one side...
