- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
So just an update...
Still looking high and low on the sources for the caps. I can get the 33's without too much trouble (more about that below), but all I can really find for the 47's are with 50 wvdc ratings. Anything bigger requires a larger diameter cap, which probably is a no-can-do with the cap clamp that the M-80 has.
But as far as having taller caps, I think I'm going to go a little bit "radical". I can't make up room on the inside (towards the main PCB), and right now I can't go the other way (towards the back) since the stock caps are already butting up against the back panel.
But.. ok... what IF I eliminate that restriction on the back end? And actually put a hole in the back panel so that the caps can poke out the back end a little? Then make a cover so that it all looks "nice"?
I think that'll be what I end up doing. But unfortunately, paycheck's already "spoken for" this pay period (we gotta eat... damn that slight "problem"!)
More after next payday, mehopes...
