- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Ok, so finally... getting to the task of rebuilding the M80. Here's the "before" pics..
Overall. Yeah, it can use some work...
Seems either it has been worked on before, or someone at the factory needed to learn how to use the alcohol and kimwipes afterwards... yuck.. all of these will be reflowed (8 of 'em per channel)
Gotta do some corrosion control on these here..
And this here? That's the main input that goes into a nasty ribbon. I think that will be replaced by some decent shielded cable.
Another wider view. I think I"m going to do some rewiring all around to make it look (and probably sound) better.. and not a rat's nest..
Then I have some caps to take care off. Here are the big bama-jama's. Looks like a blowtorch will be required to unsolder.. heheh... There are four total, and encapsulated in a plastic case of some sort. Sooo.. whatever I do get to replace should be pretty darn close to the same dimensions.
And then on the main PCB there are a few more to take care of.
I'm going to take my time and do 'er right. More coming as progress is made!
