Jason's Phase Linear P3600
#83
No, that one's full of SAE 2400. When Ron gets the audition 700 he can send it your way.
#90
Found your hum. Bad wiring harness pins coming off the power supply board. Broken solder joints.
#92
Joe, the PL 4000 isn't the only PL pre-amp that can give you a 48KHZ wall to wall square wave....
NavLinear
#97
Is all this chatter good or bad??
The total harmonic distortion and noise graph looks good Jase. Up to about 50 kHz it's around 0.04% or maybe a bit higher and moves up a bit to something near or above 0.1% - pretty damn good. It's hard to make out the graduations on the small display but Lee can print out the discrete data points.
#99
I've got the bypass caps accross pins 1,5 instead of 4, 8. For the first problem...
