Jason's Phase Linear P3600
No, that one's full of SAE 2400. When Ron gets the audition 700 he can send it your way.
I'll try to see if I can get that month down to a week..
That's way better than the alternative-------doing it yourself..........
Found your hum. Bad wiring harness pins coming off the power supply board. Broken solder joints.
Here we go..
Joe, the PL 4000 isn't the only PL pre-amp that can give you a 48KHZ wall to wall square wave....
Is all this chatter good or bad??
The total harmonic distortion and noise graph looks good Jase. Up to about 50 kHz it's around 0.04% or maybe a bit higher and moves up a bit to something near or above 0.1% - pretty damn good. It's hard to make out the graduations on the small display but Lee can print out the discrete data points.
Yes Joe, Now I'm chasing a bad channel..as in not there..
I've got the bypass caps accross pins 1,5 instead of 4, 8. For the first problem...
